I can hear from the camera, but the person in the camera can't hear me. I have an iPhone 7 with IOS 10.2. Any suggestions?
Test it on a browser to verify if it's the camera or the software. https://arlo.netgear.com/
Contact Netgear support either way as if they know, it can be fixed.
stogiepc,
Adding to the comment above, consider checking your Arlo Pro speaker volume settings as well.
Speaker volume is at 100%. It works thru the browser. It doesn't work thru the IOS app on my iPhone 7
I have tested this using a T-Mobile iPhone 6S and have not been able to duplicate the issue being described on LTE.
For those experiencing this issue:
-Does this happen intermittently or are you always experiencing this when using LTE?
-What is the quality of the LTE when you see this behavior (cell signal)?
