Out of the blue, with no changes to anything (iPad, Arlo, power), my iPad stopped recieving notifications. I just enabled it on new Xr and they work just fine. I have read through all threads and tried all solutions with no luck. Can someone give me options to try to get them back. I would rather not have notifications enabled on my phone but only on iPad. I do not want email notifications.
iPad iOS: 10.3.3
iPad Arlo: 2.7.6 (last compatible version)
Base Station: 1.12.0.1_27940
You don't say what you tried.... did you remove the app and reinstall?
I have removed the app twice and reinstalled.
restart > remove app > restart > reload > restart
tried changing all settings in notification
no rules
moved camera in and out of active
restarted base station
tried with just cellular and with just wi-fi and with both
checked do not disturb settings
changed each setting of Arlo app under settings on iOS
Hope that helps.
Are all permissions for the applowed?
As far as I can tell, all permissions are allowed.
Hi @geolyte,
In order to use the Arlo app with its full functionality, you will need to run iOS 11.0 or higher on your iPad. You can read the minimum requirements here: What are the minimum requirements for installing and using my Arlo system?
why has it worked for the last couple years? It just stopped for no reason? I haven't been running 11.0 ever and now it stops. That is not a good answer. TG
