  • 6 Replies
  • 2057 Views
geolyte
Out of the blue, with no changes to anything (iPad, Arlo, power), my iPad stopped recieving notifications. I just enabled it on new Xr and they work just fine.  I have read through all threads and tried all solutions with no luck.  Can someone give me options to try to get them back.  I would rather not have notifications enabled on my phone but only on iPad.  I do not want email notifications.
iPad iOS: 10.3.3
iPad Arlo: 2.7.6 (last compatible version)
Base Station: 1.12.0.1_27940
6 REPLIES 6
You don't say what you tried.... did you remove the app and reinstall?
geolyte
I have removed the app twice and reinstalled.
restart > remove app > restart > reload > restart
tried changing all settings in notification
no rules
moved camera in and out of active
restarted base station
tried with just cellular and with just wi-fi and with both
checked do not disturb settings
changed each setting of Arlo app under settings on iOS
Hope that helps.
Are all permissions for the applowed?
geolyte
As far as I can tell, all permissions are allowed.
JessicaP
Hi @geolyte,
In order to use the Arlo app with its full functionality, you will need to run iOS 11.0 or higher on your iPad. You can read the minimum requirements here: What are the minimum requirements for installing and using my Arlo system?
geolyte
why has it worked for the last couple years?  It just stopped for no reason?  I haven't been running 11.0 ever and now it stops.  That is not a good answer.  TG
