Arlo Outdoor Power Adapter (VMA4700) Weatherproof Issue when used with Arlo Pro or Arlo Pro 2 Camera
Dear Arlo customer,
We have become aware that the Arlo Outdoor Power Adapter/Cable (model VMA4700) may allow water into the charging port if used for continuous outdoor use. When this happens, the camera may stop charging, cease to work, or overheat.
We urge you to immediately stop using the VMA4700 Outdoor Power Adapter/Cable for continuous outdoor use in order to avoid potential property damage, injury, or damage to your camera. Please note that this issue is limited to situations where water can enter the USB charging port. You can continue to use the power adapter for indoor charging use where the adapter is not exposed to water. The Arlo, Arlo Pro, and Arlo Go cameras are certified weather-resistant and can continue to be used outdoors with the factory-supplied rechargeable battery.
Our team is working hard to remedy this issue and will provide you with an update in the coming weeks. In the meantime, please contact us for further questions. Our team will do our best to respond to you as quickly as possible.
Best regards,
The Arlo Team
____
Please click
