  • 2 Replies
  • 4844 Views
Kwenda
I have set up the Arlo chime to sound when an Arlo Pro camera senses motion.
This works well.
However how do I adjust the Arlo Chime volume ??
NOTE  I do NOT have the Arlo audio doorbell….
All the Arlo pages that I have seen show how to adjust the Chime melody, and or volume, via the Audio Doorbell, but I do not have this…
Any ideas appreciated.
ShayneS
Hi @Kwenda
When you setup the chime to be triggered by a camera, you will see the volume slider present during the rule selection. Add mode > Select Device > Select your desired motion/sound > motion/audio sensitivity > Action Device (Chime) > Type of sound profile > Loudness Notifications > If the following - Then do the following > Save
ShayneS
Hi @Kwenda
Kwenda
Many thanks, problem now solved.
I was looking to make adjustments to the Chime/Alarm settings from the devices page of the app.
Thanks again.
