Have 4 cameras. 1 is offline for no particular reason. Other 3 still connected to base. It is plugged in.
Try reinserting the battery. You should see a blue LED flash when first inserting the battery and then rapid blue flashes when it connects. You may have a dead battery which needs to be charged.
And sometimes they loose sync due a number of reasons...
Usu I try to resync first. but a battery pull resets the cam and does the same thing
