How Do I Install Arlo On New PC
  • 4 Replies
  • 2715 Views
Ancient1
I just had to replace my PC with a new one, and while most of my programs transferred over, Arlo did not.  Arlo still works on my phones and my Ipads.  What do I do to get the program back onto my new PC?
pc2k17
Hero
Hero
I assume you're using windows......... depends on what browser, but usually you just drag and drop the URL (web address) to the Desktop or to the Task Bar. Or in Edge I believe there is a Pin to Taskbar option in the settings menu (gear icon).
JoeCymru
Virtuoso
Virtuoso
It's not a program. It is a web based user interface. https://arlo.netgear.com
Ancient1
Thank you for your prompt response.  How do I get an icon on my task bar so I can access the program quickly?
pc2k17
Hero
Hero
Ancient1
Thank you!  That worked perfectly.  I really appreciate your help.
