I just had to replace my PC with a new one, and while most of my programs transferred over, Arlo did not. Arlo still works on my phones and my Ipads. What do I do to get the program back onto my new PC?
I assume you're using windows......... depends on what browser, but usually you just drag and drop the URL (web address) to the Desktop or to the Task Bar. Or in Edge I believe there is a Pin to Taskbar option in the settings menu (gear icon).
It's not a program. It is a web based user interface. https://arlo.netgear.com
Thank you for your prompt response. How do I get an icon on my task bar so I can access the program quickly?
Thank you! That worked perfectly. I really appreciate your help.
