Argo Pro set up of base unit
I just unboxed my Arlo Pro wireless cameras.
I have the base unit plugged in and attached to my Netgear wireless router ethernet port. The base unit power LED continues to show amber and the Internet LED isn't lit. The indicator on the far right is green.
I have moved the power to a different outlet and same with the ethernet cable with no changes in the indicators. My router is Netgear N300 Wireless Router WNR2000v3.
Any suggestions would be appreciated.
Try a reset of the base ... the power light should only be amber during boot up
Hold in the re-set button for about ten seconds.. the front leds will all flash amber... let it reboot ( a min or two ) and the power light should go green.
If it does, move on to the ethernet cable connection.
If it doesn't, it seems like a defect.
