Hi, I know, it has been asked a couple of times.... is anything planed in the near future, that the basic plan will support more than 5 cameras? With blink offering a cheaper wirefree cam, I'd rather buy more cams from blink than having to pay, even though I'd be running 2 systems. I'm probably not the only one. Thanks, Magnus
Nothing has been announced although competitive pressure may change that. Right now, you can use a second account with a second email address that can then be shared with the first so 10 cameras can be seen/manipulated with one login. Check out Settings, Grant Access. You will need a base station for that second accound so don't just buy cameras.
Hi, thanks for the quick response. With a second base plus another cam costing the same as a Blink starter kit with two cams..... Regards, Mag
