Hi,
Unfortunately, charger cable is dead. Do you know any compatible cable with VMS4230 cameras?
I found a VMA4400 cable but I’m not sure to buy it. Because USB port’s hole is very narrow on 4230.
Thanks in advance
The VMA4400 is a battery that comes with a USB charger.
The VMA4700 is the outdoor charger for Pro 2 cameras.
For indoor use, most USB chargers will work.
Just another user
The indoor charging cables can be an issue. However, pretty much any will work but you may need to use a sharp knife to shave down the plastic surround on the cable's camera end to get it to fit. I would just try any that you have laying around to see if they fit.
