  • 4 Replies
  • 1745 Views
kitjv
I currently have 5 cameras under the included free subscription plan. That works fine for me. However, I would like to purchase up to 2 additional cameras. Do I understand correctly that (according to Netgear) any additional cameras would require the purchase of either the Premier or Elite single-camera subscription plan for each additional camera? Also, I had read elsewhere on this forum that I could set up a second account for the new camera(s) using a different email address. Thus, I could avoid having to purchase a paid subscription. Am I correct? If so, would the second account allow me to add up to 5 additional cameras? Thank you so much.
The second account is likely the simplest solution but also requires a second base to connect the new cameras to. Then use Settings, Grant Access from the second account to the first so all cameras show up in that login.
kitjv
Thank you so much for your response. I appreciate it. In the past didn't Arlo offer a subscription plan allowing up to 10 cameras?
Yes but the 10 camera plan is now considered legacy and renewal of that has been problematic. By the time you're done, you end up with the new plans anyways.
kitjv
Thank you for the information. Much appreciated.
