- 2
Queistion about the new product - Arlo Pro,
What is Smart Siren? How's it work?
Will siren go off when intruder enter the house etc?
Since it's part of the base, try power cycling it.
I commented earlier that your neighbors should surely hear it fromt he base, but I actually never tested it outside. I just realized from the outside, it's not noticeable. So I am looking into adding an amplifier outside
In the Arlo app under mode I'm using Smartthings. Under rules, settings i have the cameras set to record motion, and i also have the Turn siren box unchecked but it still goes off if the dog walks by. Thanks
boxingjunkie,
After you integrate your Arlo cameras into the SmartThings app, you must use the SmartThings app to configure your modes and rules. If you edit your modes and rules in the Arlo app, you disarm the SmartThings mode. For more information, take a look here: What is Samsung SmartThings, and how do I use it with my Arlo cameras?
- 2
