All cameras suddenly won't charge
When I took down one of my cameras to charge, the charging symbol on the app with the lightning bolt was red. I tried charging the other 3 cameras, same thing. I've tried both chargers and cables that came with the cameras, tried swapping out cables. Also rebooted everything multiple times, removed camera and re-synched. The blue LED on the front of the camera comes on when plugged in without battery, but not when battery is in. Customer service has been of no help - only suggestion was to buy a new battery to try to isolate the problem, but I don't want to spend $50 when it seems likely the same thing will happen. It just makes no sense that suddenly 4 cameras and batteries, and 2 chargers would suddenly fault at the same time. The firmware did update in March, but I'm pretty sure I've successfully charged at least one camera since then. Anyone else have this problem or have ideas on how to solve it?
Unfortunately no, I don't have another 9V adapter to use. I ended up buying an external charging station for the batteries and it worked fine plugged into both of the 9V chargers that came with the cameras, and the batteries successfully charged in the station. So it's definitely something that went wrong with all the cameras at once.
Please contact the Support Team if you would like to investigate the issue further. You will find several options for contacting support in the provided link. Arlo Tech Support
Hi @Pam123
Are you still experiencing this issue with charging your devices? Do you have a screenshot of the error message? May I ask which troubleshooting steps you have performed so far? I don't want to suggest any methods you have previously performed.
Proved by subsitution that all my equip is serviceable however arlo admits no responsibilty.
Needless to say the camera is 2 yrs old but that is not the point.
They screwed up an update and left many camerss on this state snd then wash their hands of the issue saying the camera is defective when u prove that it is their software
