Can someone tell me the dimensions of the Solar Charger for the Arlo Pro?
  • 1822 Views
kaganrj
Rich
JessicaP
Hey kaganrj,
The dimensions for the Arlo Solar Panel (VMA4600) is 4.5 x 7.9 x .86in (115 x 201 x 22 mm).
All info (including dimensions) for solar panels, cameras and doorbells can be found through Document Library on the Support page. You will need to choose the (camera/doorbell) device and click on "Data Sheet(s)".
Rich
Someone on Amazon says 5.6 x 9.7 x 3.4 inches
https://www.amazon.com/Arlo-Accessory-Solar-Compatible-VMA4600/dp/B0721PJYTY?th=1
It would be nice if there was a KB article with dimensions for panels, cameras, and particularly doorbells.
JessicaP
Hey kaganrj,
To clarify this - if you click on the VMA4600 in the document library, all you see is the install guide - which does not give the dimensions.  You need to click on the Pro 2 camera, and then look at the datasheet.  Dimensions for the solar panel are there - though buried on page 9.
