  • 12 Replies
  • 5198 Views
Bret1979
all My options under mode have disappeared.
12 REPLIES 12
steve_t
Master Master
Where? In your app? Have you tried restarting the app? Or uninstalling the app and reinstalling it? Have you checked in the web client whether it's showing the same thing?
Bret1979
I have looked for updates and can’t find any, deleted the app and started over and no success. I can’t turn off the cameras like I normally do under more so I am continuing to get alerts that’s there is motion.
Bret1979
I have tried all those options still with no luck.
It's not clear that you tried a browser - did you? Have you tried rebooting the base? WHat are the LEDs on the base showing?
ShayneS
Hi @Bret1979
Do you happen too be on an Android device using Arlo App 2.7.1?
Bret1979
I have an IPhone x
ShayneS
@Bret1979
Do you have a screenshot of the missing settings/features?
Bret1979
I use to have three or four options under mode. They have all disappeared.
Log out and back in. Reboot the phone and reinstall the app. Use a web browser to see if things work right there.
ShayneS
@Bret1979
Along with what jguerdat mentioned, is this issue easy to replicate or is it occurring at random times?
Bret1979
It started about two weeks ago and has not gone back to normal since. The weird thing is i have done nothing with the system in over a year.
ShayneS
@Bret1979
Can you provide a screenshot of the missing options? Are the options missing on the web page as well?
