  • 1 Reply
  • 2803 Views
iGoldenEye
I currently have 5 Arlo Pro cameras with the Pro base station and was thinking of adding a Q for inside use. I've searched the forum and learned that the Q will not "send" the feed to the base and essentially work separate. My question is, I currently use geofencing and wanted to know if the Q would still work as "one unit" with the Pro cameras (i.e: turn on and off via geofencing).?
Nope. The Q cameras or wireless cameras on a second base will operate independently. You'd have to configure each base station set and Q camera separately.
