ACTIVATE siren check box
Hi
How to activate the siren check box under the rules setting? This function has completely vanished after the last updates and can't be found anymore under web interface nor the iOS Apps (Ver 2.5.4)
Any help is really appreciated. And yes, I found the drag down bar under the devices section after half an hour!!! "stupied enhancement"
Cheers
When your editing your rule, tap Add Device, you will then be able to choose your base under the siren section. This will add the siren option.
I wish this would work! I followed you recommendation but the siren option doesn't show up any more. I did an OS upgrade of my pro cameras and wondering if there have been any recent changes to the OS level? Any other ideas are highly welcome. cheers
Edit your mode, edit your rule, scroll down and choose Add Device, scroll down to the Alarms section and choose your base station.
Are you sayting when you choose Add Device, that your base station isn't listed under the Alarms section?
