  • 8 Replies
  • 3760 Views
Curtmiz
Bought 3 cameras in 2018. All cameras worked fine for 2 1/2 years. Now 2 of the cameras are so blurry it would not identify an intruder if needed. Tried removing camera and re-adding it yo base station, but no help! Look at this terrible picture!
8 REPLIES 8
Is it only blurry on the recordings?  Or is it the same on live streaming?
I think the first thing to do is take a close look at the lens (and obviously try cleaning).
Curtmiz
Cameras are blurry both on live feed and recordings.
Curtmiz
JessicaP
Hey Curtmiz,
Does your camera have that blurry image when you bring your cameras indoor?
Curtmiz
Camera is still blurry indoors too.
Dannybear
Could be condensation on the inside of the camera. Have you tried drying them out ?
Curtmiz
How do you dry out the inside of camera lens?
Dannybear
Easiest way would be to place the camera in a air conditioned environment for a day or so for the moisture to dissipate. Do you live near the coast, salt air is not ideal for electronics.
