Does anyone know if 1080p cameras will be released in the future?
Unknown , the only 1080p at this time are the Q cams and the Baby Cam
Maybe if the battery technology improves in the future. Right now you don't even get 720p unless you put the camera in best quality setting which is probably going to cut the battery life in life. If you go up to 1080p, the processing takes more battery and the WiFi transfer time will take longer, you the battery life will be down to something like charge it every 2-3 weeks.
