I have a very similiar situation as yours. I purchased 4 Pros from Best Buy this past Saturday. I have a very similair setup with one above my main entrance and one above the garage pointing at the driveway. During the day, it continuted to have several motion detections. I am pretty sure it is because the wind were blowing the shrubs which are in the camera's view. I planned on moving it to a new location, but before I did that, I noticed my camera was offline tonight. I checked on the camera to find my infrared LED's are on. They will not go off and the camera remains offline .. When the morning comes around, I will remove the battery and provide my finding. I am not sure about these cameras just yet.
The router has nothing to do with the wireless cameras since they only connect to the base.
You can try removing the camera from Settings, My Devices and resync but you may need to open a case with support if the camera is faulty.
The fact that it works near the base indicates a potential issue with the desired location. It could be distance or anything that interferes with the signal between the base and camera, such as wiring, ductwork, building construction, other 2.4GHz wireless interference, etc. Try other location, perhaps only a few inches or feet from the current one. You can use some Velcro or picture hanging adhesive strips (3M Command, etc.) to temporarily move the camera to a different location without holes.
larealboy,
Did rebooting the camera (removing and reinserting the battery) resolve the issue? Are you still seeing this behavior?
James, that appeared to eliminate the problem. I hope that does not occur again. I do not know why the infrared LED remained on, but it could be the wind was blowing the sthrubs which were in the view of the camera, setting off the motion.. Thanks for the follow up.
I tried everything Arlo Suppport Techs offered. In addition, I switched locations with another camera thinking it could be the location but to no avail. This camera still goes offline. They FINALLY approved an RMA which I declined. I don't understand why the customer must pay a shipping charge to send the camera for repair when they agree it is a problem with the camera. It appears so many have at least one camera with a problem. I am currently packing my camera to return to Best Buy.
