Why can't Netgear just test your stupid software! This si the second time you disabled the speaker on purpose or by your irresponsible develpers. Shouldn't you have some regression test?
To clarify again, when the speaker icon is grayed out, that means the audio detection is off; it is not related with the push-to-talk feature. To enable the push-to-talk feature, you will need to play the live stream on your camera feed and tap on the "microphone" button (shown below on the red box) to enable communication over the camera. Let me know if your push-to-talk feature does not work.
Maybe it isn't the software. I just tested this with a Pro camera with the latest Android app and it works fine.
Can’t figure out how to “speak” via a camera.
New download 1/12/19 of iOS app
Jack
Hi @LindaLin888888,
Could you clarify what speaker is not working? What device are you using to test this? And could you provide a screenshot that is showing the error?
Hey @LindaLin888888,
The third icon that is grayed out is if your camera is armed and it is detecting audio. If you would like to use the microphone to communicate over the camera, you will need to turn on your camera and start the live stream and tap on the "microphone" icon. You can read here on how to use the push-to-talk feature: What is the push-to-talk feature on my Arlo camera and how does it work?
Ps the camera is ON. it is only disabled for the snapshot.
Though this is marked as solved, the one poster seems to still be having an issue. One thing to insure that is understood is that the speaker icon has nothing to do with push to talk. Grey means you have audio detection off. Period. Nothing at all to do with live view. Only the microphone icon that appears within the scene view at the bottom when you initiate Live View is push to talk. However, if you start watching live view and tap it anywhere other than on one of the icon options, they (all the record, snapshot, push to talk) will disappear, I guess in preparation of tapping the screen again to get the stop icon.
If the action icons for live view are not appearing at all, then that is a different app issue. But the speaker icon has nothing to do with communication, it only is active when you have selcted audio triggered detection in the mode that is currently operating.
