  • 2 Replies
  • 466 Views
mr_crusoe
I have an Arlo Pro 6th gen camera on my balcony, facing one of the entrances to the building. It's approximately 4 meters between the camera and the entrance.
The motion detection is set to 100, but it doesn't detect when someone passes the entrance. The balcony has glass walls; could that be the problem? I couldn't imagine that would be a problem, and now I'm disappointed, having invested in an extra camera that doesn't do the job.
Anyone else who have experienced that same issue, and is there a way to make it work through windows, glass?
Sorry, but that camera will not work thru glass ( as you found out )...
It's detection method uses IR which is blocked by the glass.
You need to mount it without going thru glass.
You would need a camera that uses Pixel detection ( sees changes in actual picture )
I'm unaware of any outdoor cameras with this method currently produced by Arlo.
Or maybe the camera need ac power as some may switch over to pixel detect ?
I'm unaware of any with this method currently produced by Arlo.
If the balcony is enclosed and has power, then the Essential Indoor cameras should work.
  • 2 Replies
  • 466 Views
