  • 7 Replies
  • 1335 Views
carolinarider
I have been using ARLO devices for some time now.  I just added a couple of new devices and had to upgrade my software.  One of the things I wanted to do was to find a manual for my Arlo Smart Hub VMB5000r6.
That is impossible on the arlo website.  So, does anyone have a link to the Arlo Smart Hub VMB5000r6. manual
manual?
7 REPLIES 7
Go to Arlo.com and click on Support and then click on Document Library at the top right. Choose Accessories to find the appropriate docs for your hub (you may have to scroll back up to see the choices).
@carolinarider - all you will find there for the VMB5000 is the quick install guide.
There is no manual.
Don't look at the cameras - the hubs, etc. are found in Accessories.
Yeah.  But NO MANUAL which is what OP asked for. Not even a datasheet.  Just a quite uninformative quick start guide.
Huh - guess I didn't click on the links for testing although somehow I had the idea I had. Yer right - nothing useful there...
eTrain
