arlo 5S cameras not recording with base station and only remain on arlo cloud
  • 8 Replies
  • 45 Views
johnnyarlo
i purchased arlo 5s cameras last week along with a vmb 4540 base station / smart hub. my cameras are not recording to local hub usb and still using the 30 day cloud given with arlo purchase.
how do i connect to hub usb storage? does it happen automatically when subscription ends?
frustrating to see 2 of my old pros recording to hub but not the new 5s cameras.
thanks
8 REPLIES 8
Is the Pro 5s camera connected to the smarthub?  Or did you connect it to your home wifi?
johnnyarlo
It is connected to my home WiFi. How do I connect it to smarthub directly? I did not see a prompt for that.
thank you
johnnyarlo
Just looked at my available networks and the Arlo smarthub does not show. It would be VMB 4540.
johnnyarlo
Home Wi-Fi. I do not see the vmb4540 listed as one of the networks available. Also in the camera thumbnail there is no icon for installed USB in smarthub.
johnnyarlo
Sorry keep adding on to the reply. This is the updated
it is connected to Home Wi-Fi. I do not see the vmb4540 listed as one of the networks available and do not know how to connect the cameras directly.
i have 4 additional cameras other than the ( 3) 5s.  (3) pro 2 and (1) essential w/ spotlight that DO connect to the VMB 4540 and are listed under base station/smarthub.
Also in the camera thumbnail there is no orange icon for installed USB in smarthub For any of the cameras
thank you
When you add the Pro 5s to the account, you have the option to select the base (or alternatively connect to your home wifi). You DON'T tell it to connect to the wifi base. You just select the base.
To do that now, you need to remove camera from the account, and then add it back. You might lose the trial subscription if you do that.
johnnyarlo
Thank you for your reply..
if I were to remove the cameras and connect to base I would lose the subscription but I still have the option of recording to the USB that I added to the vmb4540 correct?
the usb icon does not show on thumbnails and that’s because the cameras are connected to the home Wi-Fi and not base hub - correct?
thnak you. You have been a great help.
john
 I'm not 100% sure that you would lose the subscription.
But you would be able to use local storage.
With cloud storage, the thumbnail is an image of something the camera captured in the recording.  With local storage, there is no image, just an icon.
So not directly related to how the camera is connected - instead it is related to whether you are looking at a local recording or not.
