i purchased arlo 5s cameras last week along with a vmb 4540 base station / smart hub. my cameras are not recording to local hub usb and still using the 30 day cloud given with arlo purchase.
how do i connect to hub usb storage? does it happen automatically when subscription ends?
frustrating to see 2 of my old pros recording to hub but not the new 5s cameras.
thanks
Is the Pro 5s camera connected to the smarthub? Or did you connect it to your home wifi?
It is connected to my home WiFi. How do I connect it to smarthub directly? I did not see a prompt for that.
thank you
Just looked at my available networks and the Arlo smarthub does not show. It would be VMB 4540.
Home Wi-Fi. I do not see the vmb4540 listed as one of the networks available. Also in the camera thumbnail there is no icon for installed USB in smarthub.
Sorry keep adding on to the reply. This is the updated
it is connected to Home Wi-Fi. I do not see the vmb4540 listed as one of the networks available and do not know how to connect the cameras directly.
i have 4 additional cameras other than the ( 3) 5s. (3) pro 2 and (1) essential w/ spotlight that DO connect to the VMB 4540 and are listed under base station/smarthub.
Also in the camera thumbnail there is no orange icon for installed USB in smarthub For any of the cameras
thank you
When you add the Pro 5s to the account, you have the option to select the base (or alternatively connect to your home wifi). You DON'T tell it to connect to the wifi base. You just select the base.
To do that now, you need to remove camera from the account, and then add it back. You might lose the trial subscription if you do that.
Thank you for your reply..
if I were to remove the cameras and connect to base I would lose the subscription but I still have the option of recording to the USB that I added to the vmb4540 correct?
the usb icon does not show on thumbnails and that’s because the cameras are connected to the home Wi-Fi and not base hub - correct?
thnak you. You have been a great help.
john
@johnnyarlo wrote:if I were to remove the cameras and connect to base I would lose the subscription
I'm not 100% sure that you would lose the subscription.
But you would be able to use local storage.
With cloud storage, the thumbnail is an image of something the camera captured in the recording. With local storage, there is no image, just an icon.
So not directly related to how the camera is connected - instead it is related to whether you are looking at a local recording or not.
Thank you for all your help. Was able to have all camera video captured on hub thumb drive. The only one not is the essential with spot light which I need to download video. Not a problem
again thank you
5s
Accessing Local Storage
Accessing Local Storage.
App
Arlo Cameras
arlo not working
Arlo Pro 5
8 -
Arlo Pro 5S 2K
Arlo solar panel
ArloPro5
audio
Automation
Blinking
Cable Length
Charging
charging unit
Clicking sound
cloud storage retention
Costa Rica
dashboard
detection
drained battery
Firmware Update
live stream
low power mode
Magenta screen
metal barns
Night vision
No recordings
Online Web
Pro 5s
Risoluzione dei problemi
Routine
Table Top Mount
VMB4000
Wifi connection
Wifi loading
wind
wireless
Zones
