Will the "Forsight" feature work using a Solar panel charger? or is using the indoor/Outdoor magnetic charging cable the only option?
@cmpeterson00 wrote:
Will the "Foresight" feature work using a Solar panel charger?
No, it requires power from a USB charger. The panels can trickle-charge the battery, but that's not enough to enable Foresight.
5s
Accessing Local Storage
Accessing Local Storage.
App
Arlo Cameras
arlo not working
Arlo Pro 5
8 -
Arlo Pro 5S 2K
Arlo solar panel
ArloPro5
audio
Automation
Blinking
Cable Length
Charging
charging unit
Clicking sound
cloud storage retention
Costa Rica
dashboard
detection
drained battery
Firmware Update
live stream
low power mode
Magenta screen
metal barns
Night vision
No recordings
Online Web
Pro 5s
Risoluzione dei problemi
Routine
Table Top Mount
VMB4000
Wifi connection
Wifi loading
wind
wireless
Zones
