Will the "Forsight" feature work using a Solar panel charger?
  • 1 Reply
  • 1428 Views
cmpeterson00
Will the "Forsight" feature work using a Solar panel charger?  or is using the indoor/Outdoor magnetic charging cable the only option?
@cmpeterson00 wrote:
Will the "Foresight" feature work using a Solar panel charger?
No, it requires power from a USB charger.  The panels can trickle-charge the battery, but that's not enough to enable Foresight.
