  • 9 Replies
  • 2367 Views
rholdcroft
I know my SmartHub is saving videos to it’s local storage, but I am unable to view these videos in the Arlo app.
I have tried everything to sort it out including restarting, resetting, using a different SD card, different device, etc.
I can’t even see the option to turn on port forwarding for the SmartHub.
9 REPLIES 9
Have you rebooted your phone and reinstalled the app? Does the pulldown menu in Library appear to let you choose local recordings?
rholdcroft
I have done both of those things, and it has not solved the issue.
I don’t have the library in my app, I have the ‘Feed’ instead.
You don't view local recordings in Feed. Use the settings for your hub, Storage Settings to view local recordings.
rholdcroft
Please see the screenshots I have attached in the first post. You will see that there is no option to view the local recordings in the storage settings. I have not been trying to view them in the ‘Feed’ as I know this is not possible with the latest Arlo app UI.
I'm gonna guess you're using iOS while I'm on Android. If so, there may be a difference, at least to some degree, between the 2 apps.
Have you tried a different device (phone/tablet)?
Direct Access to local storage is working properly on my iPhone 12 mini (running iOS 16.6)
rholdcroft
Yes I have tried several other devices and the problem still persists.
This has all started since adding a second SmartHub to my account under a different address. Now I can no longer access direct storage at both of my addresses (even when using the same network).
With the new UI (Feed) you have to have a subscription for each location. Do you?
Not for direct access to local storage.
