Looking for reliable wireless gate camera, is this the one? :)
So, my parents have a gate down below their house and I'm looking for a camera that is wireless but that is long range so it works from the house. They currently have a couple of outdoor blink cameras but they won't work down that far... I don't need to necessarily mount it, I can probably stake it in the ground, but I need it to be easy to understand and use (kinda like the bilnk) would this camera do the trick or does anyone have any other suggestions? 🙂 Thank you!!!!
Test the internet speed from the camera location using your phone.
Disable mobile data, and connect to your parents' wifi network. Measure the upload and download speeds using the free Ookla (speedtest) app.
You'll need a stable connection with at least a 2 mbps upload speed (preferably faster, to give you some margin).
Failing the above, likely the best solution would be the Go 2 which can use either cell service or WiFi. Since the WiFi probably won't work due to distance, the cell service (assuming a decent signal from the carrier at your location) would be useful.
5s
Accessing Local Storage
Accessing Local Storage.
App
Arlo Cameras
arlo not working
Arlo Pro 5
8 -
Arlo Pro 5S 2K
Arlo solar panel
ArloPro5
audio
Automation
Blinking
Cable Length
Charging
charging unit
Clicking sound
cloud storage retention
Costa Rica
dashboard
detection
drained battery
Firmware Update
live stream
low power mode
Magenta screen
metal barns
Night vision
No recordings
Online Web
Pro 5s
Risoluzione dei problemi
Routine
Table Top Mount
VMB4000
Wifi connection
Wifi loading
wind
wireless
Zones
