Update Payment option is not available (app or web)
  • 29 Views
mjamesr
The is no option for updating my payment information. Neither on the app nor the web page
JOHNK15
Why doesn't my Arlo VMC4060 battery charge. I bought the Pro 5 2K a few days ago. Also why can't I access the subscription option on my app. I'm really dissapointed with this Arlo camera!
Are you using my.arlo.com on a PC?
Are you still in the trial?
FWIW, the two play stores ( both apple and google) take a massive cut of all app purchases. I believe the current percentage is around 30%.  So Arlo (and other subscription services) often don't use that method.
If should.  What charger are you using?
You might consider exchanging it with the seller.
