Unsuccessful connection for my Arlo Pro 5s
The problem started last week.
I switched off my Pro 5s camera and I have found that the "on/off" button on the Arlo Secure apps disappeared.
I removed the camera from the apps and planned to re-install it. Unfortunately, it is unsuccessful.
I have tried to add the Pro 5s to home wifi or Smart hub, reset the camera by pressing the sync button as suggested by the webpages. The problem persists. Both wifi and Smart hub cannot find the camera.
I have taken the camera to the local authentic center. The staff checked the Pro 5s in front of me and showed me that the camera was fine and connected to their network successfully. I have repeated the previous steps again, still unsuccessful.
I am exhausted with this issue and don't know what's going wrong. I get a Pro 4 which is completely fine so far.
Arlo Pro 5S 2K
Please reach out to the Support Team to further investigate this issue you are experiencing. You can find several options for contacting support though the Arlo Mobile App by navigating to the Profile icon > Support Center > Select device > contact
5s
Accessing Local Storage
Accessing Local Storage.
App
Arlo Cameras
arlo not working
Arlo Pro 5
8 -
Arlo Pro 5S 2K
Arlo solar panel
ArloPro5
audio
Automation
Blinking
Cable Length
Charging
charging unit
Clicking sound
cloud storage retention
Costa Rica
dashboard
detection
drained battery
Firmware Update
live stream
low power mode
Magenta screen
metal barns
Night vision
No recordings
Online Web
Pro 5s
Risoluzione dei problemi
Routine
Table Top Mount
VMB4000
Wifi connection
Wifi loading
wind
wireless
Zones
