Solid Amber light on Pro 5S - Help
  • 4 Replies
  • 1920 Views
Krhyme
Hi,
My New Pro 5S 2k camera has been working fine the past few days, and is still working fine. However, I noticed the camera has a solid amber light. It is plugged into power and usually shows a blue LED - not sure why it is solid Amber.
We restarted the camera, powered on/off, still solid amber.
After checking the Arlo guides, apparently there is no solid Amber indicator for the Pro 5S 2k according to Arlo's own guides!! So not sure what this means.
Can anyone advise what is the solid Amber LED indicating?
Best answers
  • ShayneS
    Hi @Krhyme
    If you remove the device from your app and reinstall the camera, this behavior with the Amber led should be eliminated.
Krhyme
Can I get any support here please??
I don't know what the solid Amber LED signifies either.
You could try Arlo support if you have a subscription or if the camera is under warranty.
You could try doing a hardware reset.  If that works, then remove the camera from the account and then add it back.
To do the hardware reset, you remove the camera from the housing, and hold down the sync button inside until the camera LED flashes amber (about 15 seconds).
Note I am suggesting leaving the camera in the account until you know if the reset works.  That would let you reach out to Arlo support (since that is difficult if the camera isn't listed).
ShayneS
Hi @Krhyme
ShayneS
Another question if you don't mind, is the device permanently connected to a power source & Is it deployed indoor or outdoor?
