Hi,
My New Pro 5S 2k camera has been working fine the past few days, and is still working fine. However, I noticed the camera has a solid amber light. It is plugged into power and usually shows a blue LED - not sure why it is solid Amber.
We restarted the camera, powered on/off, still solid amber.
After checking the Arlo guides, apparently there is no solid Amber indicator for the Pro 5S 2k according to Arlo's own guides!! So not sure what this means.
Can anyone advise what is the solid Amber LED indicating?
Can I get any support here please??
I don't know what the solid Amber LED signifies either.
You could try Arlo support if you have a subscription or if the camera is under warranty.
You could try doing a hardware reset. If that works, then remove the camera from the account and then add it back.
To do the hardware reset, you remove the camera from the housing, and hold down the sync button inside until the camera LED flashes amber (about 15 seconds).
Note I am suggesting leaving the camera in the account until you know if the reset works. That would let you reach out to Arlo support (since that is difficult if the camera isn't listed).
Hi @Krhyme
If you remove the device from your app and reinstall the camera, this behavior with the Amber led should be eliminated.
Another question if you don't mind, is the device permanently connected to a power source & Is it deployed indoor or outdoor?
5s
Accessing Local Storage
Accessing Local Storage.
App
Arlo Cameras
arlo not working
Arlo Pro 5
8 -
Arlo Pro 5S 2K
Arlo solar panel
ArloPro5
audio
Automation
Blinking
Cable Length
Charging
charging unit
Clicking sound
cloud storage retention
Costa Rica
dashboard
detection
drained battery
Firmware Update
live stream
low power mode
Magenta screen
metal barns
Night vision
No recordings
Online Web
Pro 5s
Risoluzione dei problemi
Routine
Table Top Mount
VMB4000
Wifi connection
Wifi loading
wind
wireless
Zones
