Can you get recordings from a Pro 5S 2 K without having a subscription?
Recording in the Arlo Cloud require a subscription.
You can purchase a VMB4540 or VMB5000 smarthub, and connect the Pro 5S camera to that. Then you can use the direct access to local storage feature (which does not require a subscription). While many people do that, there are a lot of limitations - one big one is that the local recordings cannot be viewed from a PC.
How those file can be viewed?
Thank you
See https://kb.arlo.com/000062337/What-is-Direct-Storage-Access-and-how-do-I-use-it
Limitations include
- recordings can only be accessed in the app, not the web browser (my.arlo.com)
- recordings can only be accessed from the primary account (not "friend" accounts)
- there are no thumbnails, recordings need to be downloaded to your phone before you see anything
- no ability to make manual recordings or take snapshots
- remote access requires router setting changes that many find difficult, and which do not work with some internet service providers.
Thank you for your help.
5s
Accessing Local Storage
Accessing Local Storage.
App
Arlo Cameras
arlo not working
Arlo Pro 5
8 -
Arlo Pro 5S 2K
Arlo solar panel
ArloPro5
audio
Automation
Blinking
Cable Length
Charging
charging unit
Clicking sound
cloud storage retention
Costa Rica
dashboard
detection
drained battery
Firmware Update
live stream
low power mode
Magenta screen
metal barns
Night vision
No recordings
Online Web
Pro 5s
Risoluzione dei problemi
Routine
Table Top Mount
VMB4000
Wifi connection
Wifi loading
wind
wireless
Zones
