  • 4 Replies
  • 2195 Views
mwinters65
Can you get recordings from a Pro 5S 2 K without having a subscription?
Recording in the Arlo Cloud require a subscription.
You can purchase a VMB4540 or VMB5000 smarthub, and connect the Pro 5S camera to that.  Then you can use the direct access to local storage feature (which does not require a subscription).  While many people do that, there are a lot of limitations - one big one is that the local recordings cannot be viewed from a PC.
eddyrem
How those file can be viewed?
Thank you
See https://kb.arlo.com/000062337/What-is-Direct-Storage-Access-and-how-do-I-use-it
Limitations include
  • recordings can only be accessed in the app, not the web browser (my.arlo.com)
  • recordings can only be accessed from the primary account (not "friend" accounts)
  • there are no thumbnails, recordings need to be downloaded to your phone before you see anything
  • no ability to make manual recordings or take snapshots
  • remote access requires router setting changes that many find difficult, and which do not work with some internet service providers.
eddyrem
Thank you for your help.
