Starlink router is offline
I connected my Arlo and Starlink via tether…. It now say the Starlink router is offline and the Arlo was working but is now flashing orange? Any ideas I have an Alexas 10 wireless modem that they both plug into
I don't use Starlink, but it sounds like the router isn't connected correctly and you have lost internet.
I never heard of an "Alexas 10 wireless modem". Can you provide more info on that (perhaps a link to the seller's website)?
Not sure what you mean exactly by "tether". If you are using a hub, then the connection needs to be with ethernet. Some hubs have USB ports, but you cannot connect the hub to the router using those.
5s
Accessing Local Storage
Accessing Local Storage.
App
Arlo Cameras
arlo not working
Arlo Pro 5
8 -
Arlo Pro 5S 2K
Arlo solar panel
ArloPro5
audio
Automation
Blinking
Cable Length
Charging
charging unit
Clicking sound
cloud storage retention
Costa Rica
dashboard
detection
drained battery
Firmware Update
live stream
low power mode
Magenta screen
metal barns
Night vision
No recordings
Online Web
Pro 5s
Risoluzione dei problemi
Routine
Table Top Mount
VMB4000
Wifi connection
Wifi loading
wind
wireless
Zones
