  • 1 Reply
  • 4860 Views
Andrew86209
I connected my Arlo and Starlink via tether…. It now say the Starlink router is offline and the Arlo was working but is now flashing orange? Any ideas I have an Alexas 10 wireless modem that they both plug into
I don't use Starlink, but it sounds like the router isn't connected correctly and you have lost internet.
I never heard of an "Alexas 10 wireless modem".  Can you provide more info on that (perhaps a link to the seller's website)?
Not sure what you mean exactly by "tether".  If you are using a hub, then the connection needs to be with ethernet.  Some hubs have USB ports, but you cannot connect the hub to the router using those.
