Sold in the Netherlands, not supported
Just bought two pro 5 2 k ‘s. In the Netherlands, shipped by Arlo to the Netherlands. While trying to install and not having found the pro5 2k in the list in the app, support tells me (after being in the chat for half an hour, en that after searched for more then 1 hour) it is not supported by Arlo in the Netherlands. Even though the site of Arlo does not mention anything about this. And the ‘advice’ is to send it back and buy an Arlo 4 …. Bad communication and poor service.
Hi @Edwin1970
Thank you for informing me, I have escalated your case & someone from support will be reaching out to you as soon as possible. You can find your case number here: 43997235
Shayne
No one contacted me, and the case seems te be closed 🤷♂️
Hi @Edwin1970 I believe my team was able to connect with you to help resolve this by selecting the appropriate camera listed during onboarding.
5s
Accessing Local Storage
Accessing Local Storage.
App
Arlo Cameras
arlo not working
Arlo Pro 5
8 -
Arlo Pro 5S 2K
Arlo solar panel
ArloPro5
audio
Automation
Blinking
Cable Length
Charging
charging unit
Clicking sound
cloud storage retention
Costa Rica
dashboard
detection
drained battery
Firmware Update
live stream
low power mode
Magenta screen
metal barns
Night vision
No recordings
Online Web
Pro 5s
Risoluzione dei problemi
Routine
Table Top Mount
VMB4000
Wifi connection
Wifi loading
wind
wireless
Zones
