Snapshot rather than recording
I have 3 Pro 5 cameras. All were working fine until the outage last week. Since then one of the cameras keeps taking snapshots rather than recording video. Seems to be at night when it’s dark. Others cameras working okay. Anyone any ideas
It's in a low power mode, so try charging it.
What about when they were charged to 100% and still stuck in snapshot?
2 x Arlo Essential.
Have you checked routines ~ modes to make sure that take video is toggled on?
I have the same problem with one camera taking snapshots after being in low power. Checked routines and video is toggled on now and still not working.
I did end up fixing this. I believe I had to reset the entire system and maybe resync the camera. I can’t recall at all.
I had the same issue after it went dead for not charging it on time. I went to the Arlo dashboard, clicked on the device then clicked on “restart” at the bottom in red. That fixed it for me 🤗 Hope yours get fixed soon, it was annoying me so bad to only see the snapshots.
Thanks - I did try that as a last resort and it worked! it was easy to do via the app.
5s
Accessing Local Storage
Accessing Local Storage.
App
Arlo Cameras
arlo not working
Arlo Pro 5
8 -
Arlo Pro 5S 2K
Arlo solar panel
ArloPro5
audio
Automation
Blinking
Cable Length
Charging
charging unit
Clicking sound
cloud storage retention
Costa Rica
dashboard
detection
drained battery
Firmware Update
live stream
low power mode
Magenta screen
metal barns
Night vision
No recordings
Online Web
Pro 5s
Risoluzione dei problemi
Routine
Table Top Mount
VMB4000
Wifi connection
Wifi loading
wind
wireless
Zones
