How do I set the time on the Pro 5s?
You don't. It's a function of your account and its location (Home). Why are you asking?
@djbjmb - to clarify this answer...
The time zone is associated with your location, not the camera.
If you entered an address when you set up the account, then Arlo figures out the time zone based on the address. Unfortunately, they do not allow you to adjust it. You can try changing the address to something else in your time zone, and see if that works. If it does, you can try setting the address back.
If you did NOT enter an address when you set up the account, then you can set the time zone in the location settings.
5s
Accessing Local Storage
Accessing Local Storage.
App
Arlo Cameras
arlo not working
Arlo Pro 5
8 -
Arlo Pro 5S 2K
Arlo solar panel
ArloPro5
audio
Automation
Blinking
Cable Length
Charging
charging unit
Clicking sound
cloud storage retention
Costa Rica
dashboard
detection
drained battery
Firmware Update
live stream
low power mode
Magenta screen
metal barns
Night vision
No recordings
Online Web
Pro 5s
Risoluzione dei problemi
Routine
Table Top Mount
VMB4000
Wifi connection
Wifi loading
wind
wireless
Zones
