Looking to purchase this. After much googling I found out that this can or maybe cannot be paired with an
Arlo Essential 7.62m (25ft) Outdoor Magnetic Charging Cable. I really can’t find a concrete answer. Any advice would be appreciated. Thank you.
Thanks Guru. I’m more confused than ever.
both of these have the same Item No. VMA5700-100NAS
in one pic/website it’s described as magnetic, in the other they leave the word magnetic out.
need an outdoor camera, but don’t really want to change the batteries all the time. Would like to just have the battery plugged in all the time. My old outdoor camera was plugged in, it was great. Until it broke.
I'm not sure what you're suggesting. The magnetic cables of any sort cannot be used with an Essential-anything camera.
Arlo Accessories for the Pro 5s camera are here:
The Essential cameras don't use magnetic cables, so there is no "Essential Outdoor Magnetic Charging Cable". The Pro 5s is compatible with these outdoor chargers:
- https://www.arlo.com/en-us/accessories/VMA5600C-100NAS.html
- https://www.arlo.com/en-us/accessories/VMA5601C-100NAS.html
Arlo calls them "Cables", but the power adapter is integrated (and cannot be detached).
Oh Stephen, wherever did you find that! I looked all over the website and couldn’t find these. Thanks a bunch!
im looking to just keep the camera plugged in. These will work for that, yes?
I went to the accessories page and then selected the Pro 5s camera on the left.
You do need to be careful to get the correct cable for your camera.
- Essential Gen 1 cameras use a microUSB connector (VMA3700, VMA3701)
- Essential Gen 2 cameras use a USB-C connector (VMA5700)
- Pro 3, Pro 4, Pro 5S, Ultra use a proprietary magnetic connector (VMA5600C, VMA5601C)
Note Pro and Pro 2 cameras also use a microUSB connector, but they still do need a different cable (VMA4900) than the Essential Gen 1.
So if you have the Pro 5s, then the links I provided are the correct charger.
5s
Accessing Local Storage
Accessing Local Storage.
App
Arlo Cameras
arlo not working
Arlo Pro 5
8 -
Arlo Pro 5S 2K
Arlo solar panel
ArloPro5
audio
Automation
Blinking
Cable Length
Charging
charging unit
Clicking sound
cloud storage retention
Costa Rica
dashboard
detection
drained battery
Firmware Update
live stream
low power mode
Magenta screen
metal barns
Night vision
No recordings
Online Web
Pro 5s
Risoluzione dei problemi
Routine
Table Top Mount
VMB4000
Wifi connection
Wifi loading
wind
wireless
Zones
