I bought 4 Pro 5s for my daughter. I added them to her app but before she signed up for a subscription she decided she didn’t want them.
She removed them from the app, I did the 15 second reset but I can’t (no matter how many times I try) add them to my system.
We re-added one back to her system and then removed it via Arlo.com but no use!
I get to the QR code point and scan it successfully but the app can’t find the Arlo.
I've tried 2-5GHz.
Any suggestions?
Thanks.
Hi @Bill62
Is your phone connected to the same network you are trying to onboard the camera to? Have you tried installing via the web portal as well?
Phone is on the same network. I haven’t tried the on-line portal. I will but……
5s
Accessing Local Storage
Accessing Local Storage.
App
Arlo Cameras
arlo not working
Arlo Pro 5
8 -
Arlo Pro 5S 2K
Arlo solar panel
ArloPro5
audio
Automation
Blinking
Cable Length
Charging
charging unit
Clicking sound
cloud storage retention
Costa Rica
dashboard
detection
drained battery
Firmware Update
live stream
low power mode
Magenta screen
metal barns
Night vision
No recordings
Online Web
Pro 5s
Risoluzione dei problemi
Routine
Table Top Mount
VMB4000
Wifi connection
Wifi loading
wind
wireless
Zones
