Arlo Pro 5S Infrared flashing
  • 3173 Views
Dajada
Problème de clignotement de l’infrarouge lorsque j’active la vision nocturne sur une caméra. Que faire? Je viens de recevoir et d’installer cette caméra. Les autres caméras fonctionnent normalement.
Go into "Light Settings", and make sure "Behavior" is set to "Constant".
Pro5s
I’m having this problem as well. Where do you find the infrared light settings to change to Constant? All I see is ‘Black & White’, or ‘Colour’ settings for the infrared lights.
A ‘Constant’ setting so the infrared lights will stop flashing would be ideal.
It's not in the Nightvision settings.  You'll also see "Light Settings", so look in there for it.
Also, if you have NightVision set to "Colour", then you aren't using the infrared lights, you are using the visible spotlight.
