Pro5 s2k camera wont connect just blinking amber
Hi my Arlo camera that I have only had around 4 months keeps disconnecting from the internet now it just flashes amber and won't change to blue.
Best answers
@Robnant wrote:
Hi I have done that but it still won't connect it's bloody annoying 😞 it played up around a month ago then it just came to life and reconnected but this time it won't.
Probably time to contact Arlo support using the support center in the app, and then ask them for a warranty replacement.
Have you charged it?
Yes I have charged it with the solar panel and the one in the house it's still the same just blinking amber all the time, I have tried the factory reset and it still doesn't connect.
The solar panel is just a trickle charger to keep the battery topped off. When you plugged it in indoors, did it eventually turn the LED solid blue, indicating it's fully charged? If not, the battery is likely totally dead and needs some effort to charge it. Use this procedure - the key is to plug in and unplug many times until the battery gets enough charge to then allow it to charge normally.
https://kb.arlo.com/000052305/My-Arlo-Pro-or-Arlo-Pro-2-battery-is-dead-what-do-I-do
Hi when I plug it in it flashes blue for a few seconds then flashes amber again, the battery is only 4 months old should it be faulty this quick it has been showing 100% charged when on the solar so strange how it just keeps loosing connection and doing this.
Slowly flashing amber means the battery is dead. During charging there should be NO LED indication. Try the dead battery procedure I supplied to see if you can resurrect it.
Ok thank you I will try it it's not very good for 4 months old I have another Arlo camera but different type and never had any trouble whatsoever.
Managed to get it to charge and go solid blue but still won't connect when I press the reset button it goes back to flashing amber and not blue.
You may need to remove and reset it and add it back to your account again.
https://kb.arlo.com/000062880/How-do-I-factory-reset-and-re-sync-my-Arlo-camera-Arlo-Secure-4-0
5s
Accessing Local Storage
Accessing Local Storage.
App
Arlo Cameras
arlo not working
Arlo Pro 5
8 -
Arlo Pro 5S 2K
Arlo solar panel
ArloPro5
audio
Automation
Blinking
Cable Length
Charging
charging unit
Clicking sound
cloud storage retention
Costa Rica
dashboard
detection
drained battery
Firmware Update
live stream
low power mode
Magenta screen
metal barns
Night vision
No recordings
Online Web
Pro 5s
Risoluzione dei problemi
Routine
Table Top Mount
VMB4000
Wifi connection
Wifi loading
wind
wireless
Zones
