Pro 5s cameras normally show an icon in the upper left corner of the screen that says: 2K LIVE
After Support did some things remotely to fix a New Defective Pro 5s that would not detect motion, I've noticed that the 2K LIVE icon no longer shows.
It now just shows the LIVE icon as if it was a Pro2, 3, or 4 camera.
I've opened the issue with Support but while waiting, thought I'd also post it here in case others might know what's causing this...thanks.
Do you have auto track & zoom enabled?
Also, make sure the camera is zoomed out all the way.
Thanks for the reply.....no, it's off
Are you getting 2K recordings? Or are they also 1080p?
Motion Detection is not working...It's not recording.
I've escalated to "support' again.
Have bought & lived through:
Four Pro 2 + base
Four Pro3 + base
Four Pro4 - all new defective / unusable audio problems ( turns out a known / unfixable problem).
Arlo tried to replace them with 4 previously owned / used / defective returned Pro4 cameras !
Then they tried to make it right by replacing them with these Pro 5s cameras.
Am very frustrated / disappointed with Arlo quality.
@roundball we have spoken earlier in a different post. I will be closing this one as a duplicate.
5s
Accessing Local Storage
Accessing Local Storage.
Arlo Cameras
arlo not working
Arlo Pro 5
8 -
Arlo Pro 5S 2K
Arlo solar panel
ArloPro5
audio
Automation
Blinking
Cable Length
Charging
charging unit
Clicking sound
cloud storage retention
Costa Rica
detection
drained battery
Firmware Update
low power mode
Magenta screen
metal barns
Night vision
No recordings
Pro 5s
Risoluzione dei problemi
Routine
Table Top Mount
VMB4000
Wifi connection
wind
Zones
