Have 4 new 5s 2k cameras, connected thru hub. Problem is that 3 of the 4 work properly and record motion events. The 4th only takes snap shot and does not record video. Have swapped cameras around and the problem follows the camera.
It does not matter if activity zones are enabled or not. All firmware is up to date
Have tried motion detection test and the camera sees the area fine, it even sends notice of motion detected - it just never records the motion.
Added note - reviewing sit settings the "Devices with a Trial" list only shows 3 of the 4 cameras, the one that does not work is NOT in that list. No information I can find on how to add the last camera to the list. Nothing says the trial is limited to only 3 cameras.
It's not.
How long have the cameras been installed?
Cameras installed less than one week. Have removed battery, reset camera, removed from list and reinstalled. Still shows up with only three on trial.
Try contacting Arlo support using the support center. You'll need to pick a camera that is in the trial to reach them, and then explain the problem. Chat will put you through a bot first, so you could move directly to phone support.
5s
Accessing Local Storage
Accessing Local Storage.
App
Arlo Cameras
arlo not working
Arlo Pro 5
8 -
Arlo Pro 5S 2K
Arlo solar panel
ArloPro5
audio
Automation
Blinking
Cable Length
Charging
charging unit
Clicking sound
cloud storage retention
Costa Rica
dashboard
detection
drained battery
Firmware Update
live stream
low power mode
Magenta screen
metal barns
Night vision
No recordings
Online Web
Pro 5s
Risoluzione dei problemi
Routine
Table Top Mount
VMB4000
Wifi connection
Wifi loading
wind
wireless
Zones
