I am unable to connect WIFI to Netgear NightHawk RAX120 router. I tried and following every steps from Arlo support site but no luck. Every time scan QR code and hear a chime from the Pro 5s 2k success but it was keeping search the device forever. I tried to reset my router with no help at all. The router works prefect without problem. Can anyone have same issue?
Check the router's attached device list after you hear the chime.
Let us know if the camera shows up in the list.
Occasionally a reboot of the router fixes this sort of issue.
check the router attached list after hear the chime right away with refresh but no connection
I have also reboot and reset the router to default configuration but still no luck!
Ok. That suggests that the camera is unable to join the network. FWIW, it'd be nice if the camera followed up with a second tone indicating either success or failure after the chime (which only says that the camera read the QR code). But it doesn't.
A couple of things to check:
- make sure the router wifi is set to WPA2 (AES) security - not WPA3.
- if you have any punctuation, spaces, or other "special" characters in the wifi name or password, then try removing them.
5s
Accessing Local Storage
Accessing Local Storage.
Arlo Cameras
arlo not working
Arlo Pro 5
8 -
Arlo Pro 5S 2K
Arlo solar panel
ArloPro5
audio
Automation
Blinking
Cable Length
Charging
charging unit
Clicking sound
cloud storage retention
Costa Rica
detection
drained battery
Firmware Update
low power mode
Magenta screen
metal barns
Night vision
No recordings
Pro 5s
Risoluzione dei problemi
Routine
Table Top Mount
VMB4000
Wifi connection
wind
Zones
