I have 2 Pro 5S cameras and they worked fine for a few months and now they do not detect motion and record. I have 4 of the Pro 2 that are working great connected through a dash station. The 2 new Pro 5S cameras are with a subscription and connect to my network just fine. They were great, but suddenly, both just stopped detecting motion and recording. I can still get live view. So it does not appear to be a camera view issue. I have restarted one of them and it does not appear to fix the problem.
From reading other posts, it sounds like a firmware issue. Has this been resolved and/or is it being resolved?
Check your subscription status to verify that the cameras are shown as being included. If you have a legacy subscription, you may want to unsubscribe from that and purchase a current one.
5s
Accessing Local Storage
Accessing Local Storage.
App
Arlo Cameras
arlo not working
Arlo Pro 5
8 -
Arlo Pro 5S 2K
Arlo solar panel
ArloPro5
audio
Automation
Blinking
Cable Length
Charging
charging unit
Clicking sound
cloud storage retention
Costa Rica
dashboard
detection
drained battery
Firmware Update
live stream
low power mode
Magenta screen
metal barns
Night vision
No recordings
Online Web
Pro 5s
Risoluzione dei problemi
Routine
Table Top Mount
VMB4000
Wifi connection
Wifi loading
wind
wireless
Zones
