Pro 5S connected to basestation on old firmware
Hi all,
I have a 5S Pro, connected to a base station for a few months now. It did the initial firmware upgrade to the 1.040.26.2.
After that, nothing. I see a few more recent releases, with the 1.040.27.5 as the latest.
I rebooted the camera, but the new firmware doesn't show up.
Any reason why I can't get the 27.5?
Thanks!
Where are you? Updates don't get to all parts of the world at the same time. Any chance your setup is via Verisure?
I’m in the UK. I know it doesn’t get released everywhere at the same time (or not at all?), but I couldn’t find any regional information.
should I just wait and pray? 😀
UK apparently has to get updates approved by Verisure. I don't know the specifics but it appears that Verisure is Arlo's partner in that region which can slow things down. Not much you can do except wait.
Thanks, I’ll dig into this.
is this the case even if I got the cameras directly from Arlo?
Yup. It's all about where you set the system up.
5s
Accessing Local Storage
Accessing Local Storage.
App
Arlo Cameras
arlo not working
Arlo Pro 5
8 -
Arlo Pro 5S 2K
Arlo solar panel
ArloPro5
audio
Automation
Blinking
Cable Length
Charging
charging unit
Clicking sound
cloud storage retention
Costa Rica
dashboard
detection
drained battery
Firmware Update
live stream
low power mode
Magenta screen
metal barns
Night vision
No recordings
Online Web
Pro 5s
Risoluzione dei problemi
Routine
Table Top Mount
VMB4000
Wifi connection
Wifi loading
wind
wireless
Zones
